Upgraded Steering Linkage Bolts
1BadTundra
212X
Ok. Wait no more. Here is the final setup. The bolts are 18-8 stainless. M6 is not available in 303 stainless. So hopefully they'll stand up to salt water. If you keep them lubed, I don't see an issue.
Do you have part numbers for the correct hardware?
RobbieO
Sacramento River Delta
212SE
dshscarab
South Florida
AR195
Question, where did you obtain the bushing from? Is there a source or part number for them. I am also tired of the play in the wheel.
RobbieO
212SE
dshscarab
South Florida
AR195
Nevermind. I just found it and ordered a set.
sailorkane
LS
316 stainless is the better marine salt water grade. Mcmaster 90269A552 is M6-25 with .08 (coarse thread). 90269A564 is fine thread. Super expensive in black oxide, though. 90269A548 fine in regular finish. 90269A145 regular finish coarse thread. Still super expensive. Allen head. I wouldn't worry about the 18-8 (analogous to 304) though--it should be fine going in and out of the water. Its air that gives the stainless its rust fighting capabilities.
Southside
Thank you for posting this info. Just ordered a set of screws and bushing, appreciate it!
