1.8L SVHO: First DIY Spark plug & Oil Change Experience & Tips
Farny
Spring TX
Centurion
Ribs77
PNW
Great writeup.
I didn't change the plugs at the start of this season because I know the previous owner changed them before last season and didn't run the boat all that much. (I did change the oil.)
Maybe I'll change them halfway through the season, but do you think I can get away with waiting until next season?
anmut
212S
Question- how do you reset maintenance alarm?
Go into your settings, there's a maintenance button that will allow you to reset your hours since last oil change.
biffdotorg
Pelican Rapids, MN
Great writeup.
You can get away with multiple seasons. Read your manual and go by hours, not years. As these plugs should be inspected, possibly wire brushed and cleaned, but replacement is not necessary.
And for anyone that replies, "it gives them piece of mind" loves to waste money and must have the impression that if a spark plug goes, it's catastrophic failure, which it is not. You may or may not hear a miss, or a drop in RPM's. Then gap a new set and swap them.
adrianp89
Tampa Bay, FL
252SE
You can get away with multiple season. Read your manual and go by hours, not years. As these plugs should be inspected, possibly wire brushed and cleaned, but replacement is not necessary.
Sure but at $30 and 10 minutes… why not? It’s much quicker to change them than to clean them.
biffdotorg
Pelican Rapids, MN
Why would you not go to the gas station and dump 9 gallons of gas on the ground? It only takes 10 minutes. Both activities gain you nothing except take $30 out of your pocket.
I'm not being cheap about this, I have $30. But why do it if the boat is running exactly the same. I'll give you one better, I don't even inspect my plugs unless I hear a miss or see a drop in RPMs. Now I've saved the 10 minutes as well
These are not two stroke waverunner engines. My pair of GP1300r's get new plugs once a season. My old Yamaha SRX700 sled used to eat at least a set of plugs per season. My 242ls saw new plugs after 4 seasons without a loss of MPH or RPM's. My Yamaha Apex snowmobile didn't see new plugs till it hit over 12,500 miles! Most folks don't run a sled for half those miles of total ownership.
There are things you do for performance, or piece of mind. But plugs on modern efi fourstrokes is not one of them.
Ribs77
PNW
Please sir tell me where you can get 9 gallons of gas for $30 😅 Gas is $6.99 for 87 octane at the nearest marina to me (which I can't/won't even use since I have a 195). And about $5.50/gal for premium at the pump if I want to trailer up.
I recently had a cylinder misfire on my minivan (V6 Honda) and I could hear it well before it threw an error code. I did change those plugs, disabled the VCM, and that fixed the light and the misfire.
I feel good about leaving my plugs in the boat until next season at this point. Thanks, all!
biffdotorg
Pelican Rapids, MN
You get the idea. Do what makes you comfortable. The manual is not a bad reference. You are are going to do well with your boat. and it will serve you well. At least you asked.
sorry your gas is so expensive. We don’t have a marina on our lake.
