2005 AR230 - Driveshaft Grooves
JodyHarrison
Warrior, AL.
Going to go on ahead and dive on my sword here. Yes, the 2nd time out I sucked up the tube rope and have received a great education on the jet pumps. However, I could not have fixed it without all of the great info you guys have here. Thank you for a great forum.
I replaced the bearings in both jet pumps but while I had the Starboard drive shaft out I noticed grooves worn into the drive shaft. The Port side was smooth as it should be but the Starboard has what I would consider pretty deep grooves up close to the splines and some closer to the impeller. I put everything back together and installed it back in the boat but it is just bothering me knowing the grooves are in the shaft. I feel like I need to replace it but also hate to spend the money if it is not needed.
Thoughts?
Scottintexas
Corinth, TX (DFW)
those grooves would be aft of the hull fitting aren't they ? you could see the grooves in the jet tunnel while the impeller is installed ?
Ronnie
SF Bay Area
If you are not experiencing any cavitation or loss in performance I think you should keep using the grooved drive shaft but start looking for a new or used spare as well.
JodyHarrison
Warrior, AL.
yes sir, that is correct.
I'm not sure if it affects performance because I had only taken the boat out 3 times since I bought it. Once for about 30 minutes test driving, the 2nd time for about an hour just trying to get a feel for it, then about 20 minutes before I sucked up a rope which led to all of this. :) Oh what joy! hahahaha
But, even had I not sucked up the rope, I would have been at this point anyway. When I was changing the bearings, they did not feel good at all. Very rough feeling and would catch as I tried turning them. So really, I am glad it happened when it did.
