HangOutdoors
- Royal Oak, MI
I wanted to put SeaDek everywhere in my 2020 AR210. Bow floor, cabin floor, short step to swim deck as well as large step. Finally anchor locker and bow gunwales. I reached out to SeaDek and here is the response I got. I did talk to a Certified Fabricator and they wanted almost double the price. How long does it take before they usually have a template on file? Was there any change from 2019 or 2018? except the recommend a slightly different color.
Thanks for your interest in SeaDek Marine Products. Unfortunately, we do not yet have a template on file for your 2020 Yamaha AR210. However, there are still a couple of different ways to get SeaDek on your boat.
1. Contact one of our Certified Fabricators or Installers in your area to help you with a custom order (SeaDek Certified)
2. Determine the size of the area to be covered and order the appropriate size sheets (Sheet Material - Retail Items) pattern, cut and install it yourself. SeaDek is easy to cut and with a reasonable amount of care excellent results can be achieved at considerable savings over a custom SeaDek solution.
3. Order a template kit ( Template Kits - Made To Order ) make template patterns of the areas you would like to cover and return them to us. Photos taken of the completed templates taped in place on the boat are very helpful as well. We will then scan the patterns and provide you with a quote to make a custom-fitted pad for your boat.
