HangOutdoors
- Royal Oak, MI
Yes on yours it would be the two lower ones.
Dealer- checking it is part of delivery and setupThe bunks stick out several inches, so there is room to move it back. If the axles need to be moved, Shorelandr and/or Yamaha is going to rectify that. Selling me an unsafe setup is negligent=Lawsuit
Thank you sir. Should take less than 3 minutes.Yes on yours it would be the two lower ones.
I'm hoping you were able to get thYes on yours it would be the two lower ones.
Moved the winch back 3 inches today. Tows so much better. Still have to winch the boat on the trailer. Will recheck the tongue weight tomorrow.I would still confirm and validate anything the dealer does, since they didnt do it correctly in the first place. And tbh, some do not do the same level of thoroughness that I or you would do.
Ok so the weight would be helpful, is the back of the boat now even with the bunks?I'm hoping you were able to get th
After I check the tongue weight, I still have room for adjustment. After I moved it back, the bow roller squeaks like hell. I'm waiting on a custom roller, mine is too tight and doesn't move at all. I have the same set up as you. RP-446 with bottle caps. I like it.
Is yours twin engine? I was wondering if the tabs would interfere with the Cobra fins.
I would of thought the actuators would be more vertical. Not much choice there.
Yeah I will have to adjust, as I cannot understand why you would have bunks not under the boat.@SCP1 unless your axles were moved or they set up your bunks wrong, you gotta be pretty heavy on the tongue weight.
My assumption is they just have the front stand (the post with the winch) or whatever you call it too far forward.Could the bunks have been cut to long? Or those bunks were ment for a different trailor.
