Adding a Trailer Hitch to the Boat Trailer
woodard1983
Polk City, IA
I think a couple people have done this if I remember correctly?
I'm looking to had a hitch to the back of the boat trailer so that I can pull the jet ski behind it. Has anyone done this? If so, where did you go to get it done, a regular body shop? I've called the local marina and a few other places I thought might do it and they all said they aren't sure where I should go :(
Also, how much work/modding is involved?
Ronnie
SF Bay Area
I recall seeing a pic of a setup like you described, I think it was an avatar of a YJB member. Anyway, it didn't look complex, the receiver for the tongue was welded to the bottom rear cross support.
I would be more concerned with the legality of such a rig. In ca if you want to tow two trailers with one vehicle the first one needs to be attached via a fifth wheel. I'm sure this applies to other states as well but I'm not sure which.
GiddYupJoe
Beavercreek, Ohio
jdonalds
Redding, CA
That would be illegal in California.
I had a receiver welded to the back of a tent trailer so I could attach our bike rack. The local trailer shop did it for me.
sstegh
Menomonee Falls, WI
In Missouri we can trailer like that. I've thought about having that done so we could take a popup trailer and the boat camping. It would scare me if I had to back up....
woodard1983
Polk City, IA
It's legal in IA, KS, MO, & NE. Not sure about other places, but that has been 100% of my boating to this point so it should be good....
I'll check the welding shops around and see what I can find, Thanks everyone!!! :)
CDENsomnia
Linwood, KS
Actually in KS you have to have a fifth wheel as the first trailer and it must have electric brakes and a breakaway. The second trailer just needs to have lights. I researched the heck out of it because I had a fifth wheel with a waverunner on the back.
woodard1983
Polk City, IA
hhhmmm, I'll have to check into that....I spoke w/a KS state trooper and he said it was fine...thanks for the heads up, I'd rather not get in trouble for something like that ;)
CDENsomnia
Linwood, KS
Ha! I too was worried about getting stopped. I also spoke with a State Trooper but actually went to the local inspection station and they said it must be a fifth wheel for the first trailer. I think I have a PDF somewhere of the actual verbiage the state uses. I will see if I can dig it up.
itsdgm
Not sure what you're using as a tow vehicle, but it might be easier (and safer) to put the jet ski in the back of a pickup truck, then tow the boat behind the truck. There's some pretty nice carriers that are made to fit into truck beds.
Wayloncle
73703 Enid, OK
I saw a boat trailer on here (I think) that had a ski carrier in front of the boat, the person had bought the boat and was wanting to get a normal trailer if I remember correctly.
woodard1983
Polk City, IA
cost of $1-200 vs a few thousand for the haulers has me nixing that idea....It's a single ski, nothing unsafe about it...the only limiting factor is that you lose the ability to back up
with that being said, i wouldn't ever think about it in Cali...much different traffic/roads here in the midwest ;)
mmgg
thunder bay ontario
In Canada I heard there is a max. length something like 50 feet for truck and trailers.
