Another impeller question
Xsannz
Where are the serial numbers on the stock impellers?
I have just Purchased a set of stock impellers and shafts and wear rings from another forum member but thought I'd ask the question.
How do I know which side is which, do the have part numbers stamped on them?
Acard7
SW Iowa
I would assume there’s a part number stamp somewhere.. The only part number difference that I can tell is the impellers, the rest of the parts are the same numbers for either side. Obviously keep the wear rings with the impeller it went to in the first place since they are used.
Partzilla for your 07 AR230:
Starboard impeller 6P6-R1321-10-00
Port impeller: 6P6-R1321-00-00
Scottintexas
Corinth, TX (DFW)
there are no serial numbers on impellers. they do have a part number,
this is from my 2007 manual,
