AR192 Wakesurfing
SamCF
Greenville, SC
SX192
Finally got to try surfing again today. I moved the battery under the swim deck, and was able to get a full 800 sack in the port compartment.
800 port under seat.
540 on swim deck port side
About 300 starboard under seat.
Pretty good wave. Never really dropped the rope, but was able to find a sweet spot where the rope was slack. Turning to surf side gave good push, but it was inconsistent. Wave was hitting just above my knee.
I had my wife move around the boat to see the wave change, but She didn't like being called ballast.
Tomorrow I'll try a bag in the swim compartment instead of the starboard under seat. Struggled to get up to speed with all of the weight on the back. With my wife in the bow it popped right up. Amazing how much a little weight adjustment changes the wave.
SamCF
Greenville, SC
SX192
Van T
Chesapeake va
You need a board one more float
SamCF
Greenville, SC
SX192
600 lbs on upper swim deck. No other ballast, only myself and my 9yo son in the boat. I've tried every combination I can think of with up to 1800 lbs of Ballast. Nothing comes close to working as good as 600 lbs on that surf side back corner.
haknslash
Lake Martin, AL
Moomba
Same results I had when I tried up to 1400 lbs, DIY surf gates, etc. Nothing compared to my "lil bag that could" :D. Puts the weight right in a sweet spot on these boats.
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
You dont need another board, just more practice. You will get there. Looking good.
Mike Day
I’m completely new to the boating world and recently purchased a 2014 Ar192. I’m curious how you keep the 600 lb bag in place and where exactly it rests?
SCP1
DeForest, WI
212S
Honestly if you don’t already have a bag just get the 19’ specific one from jcyamaharider. He has handles on it so you only need 2 ropes on it.
SamCF
Greenville, SC
SX192
The bag I used was 800 lbs, but wasn't full. Ended up randomly wrapping ropes around the bag to tie it down. There isn't a good way to tie it down. It was on the upper swim deck on the port side.
Just get the custom bag for the 19' boats. The trouble and inconsistency of the standard bag takes away from the overall experience.
Arcadyus
Washington
Moomba
Wake
I have the transom ballast bag on my AR195 which is 550lb. All you need other than that is about 350lbs in the bow and I can go ropeless. The wake is close to the boat but I dont give a shit. I may try going to 10.5-11 but yesterday the best push was at 10, but your maybe 3-4 ft from the boat.
Tayhadasuperjet
What have you found to be the best speed on RideSteady for surfing?
anmut
212S
Best thing about RS is that you do .10mph increments based on conditions and rider. I'll pull a baseline wave with nobody riding after the bags are setup to get the speed right (based on water depth and human ballst), then when surfer is up, adjust slightly to bring in that nice curl.
Ribs77
PNW
Dumb question about bags like this... how do you fill it?
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
You use a tsunami ballast pump.
