BOATS & BIKES
vwallat99
Minnesota
SeaDoo
Challenger
Wow very nice. Looks like you don't have only a few months to enjoy everything though! I need that
Neutron
New Bern, NC
Started tearing into the H2 today.
Pulled the carbs to clean them out
Gonna send the tank out to get restored if i can't find a decent replacement.
Verified spark is good on all 3 cylinders.
Pistons look rough so i am going to pull the engine and rebuild it.
Found the owners manual under the tail lamp, and the 3 original replacement spark plugs still in its holder
20240211_154914.jpg20240211_154900.jpg20240211_154834.jpg20240211_154843.jpg20240211_154818.jpg20240211_141447.jpg
SantaFeTrailer
Santa Fe, New Mexico
I love how those pipes follow the lines of the bike
Finished working on the Victory a few months ago but never had time to post about it.
Added flush mount turn signals front and rear.
Did a Llyods Torque Tube Intake with twin filters, and a Power Commander V with custom tune.
And an RPW slash cut exhaust with O2 delete.
Also not pictured, I went with a Metzler 250 rear tire and added 4in forward controls.
It hasn't been Dyno tested yet, but based on the same mods being done on other hammers, Lloyds estimates apporx. 122hp vs the stock 96hp. It definitely has a really noticable seat of pants difference.
SantaFeTrailer
You know that you are probably going to die in a firy crash just from having that in your shop right? I mean, still worth it and all.
View attachment 215032View attachment 215033View attachment 215034View attachment 215035View attachment 215036View attachment 215037
Neutron
New Bern, NC
Yup worth every second.
Probably not drive it much but will restore it and add it to the pile of stuff my grandkids get when I am ashes lol
Be O Be
Wake
The good old days!!!
Neutron
New Bern, NC
After my H2 engine tear down, i was sure i was going to have to bore the cylinders because the center one that was destroyed looked like this
But after some patience with some muriatic acid, a razor blade and scotch bright. It looked good so i used 3 different ball hones ending with a 600 grit hone, this is the end result
All still within stock spec.
Ordering pistons and gaskets and it will be back together and running soon
Neutron
New Bern, NC
Finally got to spend a few hours on the H2 today
Got the top end back together and bled the oil injection. Hopefully this weekend i can put the exhaust back on, then the carbs then fire it up on the fuel bottle.
