Chart plotter
Brian_NY
252SD
2017 SX240
I recently bought a hummingbird Helix 5 di GPS G2 with a navionics map card. I was very disappointed to realize that the Helix 5 is unable to do dock to dock routing. I took it all apart and I am returning it to Amazon today. Does anyone know of a 5-in GPS that is capable of dock to dock navigation? I'm having a hard time finding anything with that screen size. As always, thank you.
Robconn
Lake Lanier, GA
AR192
2017 SX240
A cheap alternative until you purchase a dedicated gps with dock to dock would be to install navionics on your phone. $15.00 / year subscription. I graduated to an iPad. With cellular. at the least, that will work dock to dock. In addition, a waterproof cover for phone or tablet, and ram mount would protect from elements and secure device to boat. I used a ram mount with a clamp in order to avoid drilling and adding fasteners in the fiberglass. Idk about a few miles offshore as I boat on a lake. I will consider a dedicated system but not until I upgrade to a larger boat.
Brian_NY
252SD
Thanks. I do have a subscription for my cell phone as an alternative for now. Now I have holes in my dash and have to buy a new one now. Disappointed.
watdog
Hampton, Virginia
I spent a lot of time researching chart plotters with dock to dock and bought and returned my first Garmin to buy another that will actually do dock to dock. With that said Garmin owns Navionics so I thought it would be just as good. Nope. The smaller screen you go the less likely you will find this feature. Many makes claim Navionics auto-routing, including many Garmin but then you find out you need to spend $$$$ to buy an SD card and a subscription. I bought the GPSmap 742xs but I would NEVER trust its dock to dock at all. Navionics is by far the best on a tablet or phone. I did a side-by-side comparison of the 742xs and Navionics on a tablet. Trust Garmin auto-route and you will end up beached.
Brian_NY
252SD
Great write up, thanks. How is the glare on a tablet, I would think it might be hard to see. My cell does work great but I wanted something a little bigger and fixed.
Robconn
Lake Lanier, GA
AR192
I have a lifeproof case. Glare is occasional but is something that I can minimize by increasing screen brightness and repositioning when necessary. I installed a USB port as a battery backup. I hardly use it. While at a cove, I use an anchor alarm app and can toggle back and forth between apps.
Brian_NY
252SD
Brian_NY
252SD
Thanks for the info. I am going to look at a tablet with high nits for sunlight viewing. Then I can use the Navionics app on it. :)
watdog
Hampton, Virginia
Tablets are good but my issues were getting it to stay connected to my phone's hot spot, the polarization of the screen, and overheating. That's just with my equipment, your results may vary. I still keep my phone on the ready with Navionics.
If you are looking for a secure mount that requires no drilling:
Scuba_ref
Wenatchee, WA
Are they the 4.5 inch or 6 inch mounts? Do you have a link to the one you bought?
Robconn
Lake Lanier, GA
AR192
I could not get link to work from amazon but here is a screenshot of item. Ram mount for tablet that does not require drilling. Item listed as: “Chargercity xt boat helm pole bar spin bike tablet mount w/ universal tablet holder for iPad Pro, iPad Air, iPad mini, galaxy tab s, surface pro book, & all other 7”-12” screen tablets”
Brian_NY
252SD
Great info !
watdog
Hampton, Virginia
It was the 4.5" Naked Flex. It's $100, but it is a quality item made in the USA. Ok still not worth $100 but works.
Scuba_ref
Wenatchee, WA
Thanks, if you go to their website right now it was $20 off with the code KRAKENOVERSEAS
