Check you Seat Bolts
throttlebc
Round Rock, TX
FYI to any 2021 owners, or perhaps earlier years. My 2021 only has 8 hours on it and I found today that the seat bolts holding the seat to the stand/slider were only hand tight. Two had actually worked completed out and were on the floor of the boat and the remaining 6 were loose. Whoever had that job at the factory took an early break it seems. It's easy to fix, but it would be a definite annoyance on the water!
Jeel
Toms River NJ
You better check your house clamps too , if those are hand tight you are screwed
throttlebc
Round Rock, TX
Good point. I checked all of the ones under the rear access panel when I re-sealed it a few weeks ago, but I'll put a tool on every fastener I can find when I do the first 10 hour service in a few weeks.
Jeel
Toms River NJ
I like that you are doing the
i like that you are doing the first service so that you know things will get checked and tightened if needed because the dealer wont do anything but change oil and filters
jetboatjay
Naperville, IL
AR195
I have a new AR195 and found a machine screw on the deck in front of the motor cover on Saturday. I couldn't find where it went, but I didn't check the driver seat stand. I will look into that tomorrow, thanks for the heads up.
Ryno
AR195
Couple minor issues with my new 195 I got Friday... The pad on the back deck had a large air bubble in it... Just used a utility knife to get a hairline slice in it and re-attached by putting plenty of pressure on it. Seems good now.
Also, the stereo has a small fogging spot on the screen about the size of a dime. Comes and goes, but the weird thing is there had been absolutely no water anywhere near the stereo. It was the a few minutes after I first turned on the boat was dry. Works fine otherwise, and honestly will prob just upgrade the stereo to an XM/serius ready receiver by next summer anyway.
This is great - hopefully there are just a few minor QC issues with the early release and we can all just share some of our experiences with these new boats as we all get them and try them out!
ScottS
Salt Lake City, Utah
AR195
On our 2017 AR 195 - bought this year with 5.8 hours on it we have had some issues that are worth noting. Seat bolts all had to be re-tightened as they kept falling out. Ended up using thread locker on the. Also, that machine screw you mentioned @jetboatjay is likely from your Bimini. Check the two screws for tightness at each of the four bimini ball and socket attachment points. I had a screw hit my sister in the head while underway and couldn't find where it came from. We took the boat home that evening and couldn't find where it came from. When we arrived back at the launch the following day our bimini was hanging cock-eyed off the wakeboard tower and I had lost another screw... hopefully this is where yours originated from.
I am going to re-mount the bimini and use blue Loctite thread locker to hold them in place.
Side note - does anyone use red Loctite on their bolts on the boats? I am hesitant to use a "permanent" thread locker on anything that may need to be replaced in the future.
jetboatjay
Naperville, IL
AR195
Had a bubble in my seadek on the driver side bottom back deck as well. I pressed it down and crossed my fingers. So far so good.
JetMania
Lee's Summit, MO
212S
My driver's captain's chair only has three of the four bolts. Never found one on the floor, but I was just checking various fasteners. I thought someone posted the spec's on the bolt - size and thread, but I don't see it on here. Can anyone help??
gallobg
MasterCraft
I have a 2019 AR195 and sadly have found that I have had to check virtually every exposed screw. So many were loose. I've also found my fair share of random screws, washers, nuts, etc. I started a collection bag and hopefully I will figure out where they go sometime.
The most difficult / frustrating ones were the bolts that attach the engine hatch hinge at the step-through area. There are two on each side. Both bolts on one side completely fell out and the the ones on the other side were nearly out. It was a PITA to put those back on and fight the gas shocks. Suggest that everyone check those!
JetMania
Lee's Summit, MO
212S
My dealer has 2021 SX195 available if anyone is looking or knows someone who is. Surdyke Yamaha in Osage Beach at Lake of the Ozarks. Tell them I sent you.
throttlebc
Round Rock, TX
I just checked one and it seems to be 1/4”-20 course thread x 3/4” long with a 3/8” hex head. I don’t have a catalog to reference, but that’s what I’m measuring.
JetMania
Lee's Summit, MO
212S
That is very helpful! Thank you!!
212s
1000 Islands
212S
That's a great find! I put about that many hours on it the first day on the water!
I've used blue Loctite for years and the screws/bolts are still secure, even those that get wet or are submerged. No need for red unless you intend to never ever take it apart. You need some heat to break red Loctite, like a torch or similar, and you might damage the finish on the tower or worse set the bimini on fire!
o_O
JK about the bimini, but blue is plenty strong and durable.
212s
1000 Islands
212S
Sadly this is probably due to rushing boats out of the factory after COVID shortages. Those seat bolts probably lacked Loctite?
I'm not sure if we're lucky or what, but I've only found a couple loose screws and bolts - I was expecting more issues from complaints on this forum. No leaks in the engine bay which I check every outing, so far so good. My boat was built Feb 2020 and might have been a slower time and not rushed so much. But at least loose screws and bolts are easy fix like you say.
LM-Jet
212SD
Just noticed captain chair tilted forward. Noticed on only 2 bolts are holding the front down. This explains it. Did not look on the floor it was getting late and we were 2/3 done putting cover on. You say there are 6 bolts?
This forum is so informative
blamphere
252SE
I had every single bolt fall out of both seats. Hand tightened them as they came because I always forgot to bring a socket set with me every time we went out. Finally put them all back in with loctite when I winterized. Next year they will be good as new!
