Enovation Marine Stereo
jacoviii
Independence Mo
255XD
I was helping another member that has the same problem in his '21 255x. I will see what he end up doing.
sandler312
Chaparral
VRX
Hey @Gmeyers,
I had a similar issue with putting in a Wet Sounds Marine PA system inbetween the existing output from the head units and the AMPS. I got all the correct TE connectors made the terminals/plugs, and then I would hear a hissing sound once the boat was turned on. I thought I reversed a connector made no sense. After all trial and error I found out that if I plug the RCA's into my EQ input after the amps turn on works like a champ. I have no idea why and how I even figured this out but it is super annoying to have to do this. I even got a delay timer for my EQ whcih delyas it from turning on for 60 seconds and it still has an awful hissing sound. Only way I found was plugging in RCA's after the amps turn out. if anyone can solve this would be a game changer for me as well.
1WetBoat
Tampa
Here is the AMP and connection to the Connext display that is in the 2022 AR250 and other boats I'm sure....View attachment 175857
My 2021 AR250 doesn't have an AMP like the one in your PIC. The Connext goes connected directly to the WetSounds AMP via that same plug.
gmeyers5
Hey @Gmeyers,
That was exactly my issue too. I'm please to say as of today it is fixed. LC1i was the answer as someone in this forum suggested. The head unit needs to see 20k ohm load on the input or it faults. The LC1i was a plug and play fix. https://www.amazon.com/AudioControl-2-Channel-Converter-Amplifier-Distortion/dp/B08WPRG5F2/ref=sr_1_3?crid=23UVVU5PREIDZ&keywords=lc1i&qid=1650577124&sprefix=lc1i,aps,75&sr=8-3. I connected the remote-in line on the RC1i in parallel with all my other components.
RC250
Stockton CA.
Can you take some pictures of your wiring im installing some speakers and new amp have same boat as you do with the same no brand amp from factory
gmeyers5
Will do tomorrow when I get all wired in proper’!
jacoviii
Independence Mo
255XD
Good to hear that you got it fixed
adrianp89
Tampa Bay, FL
252SE
