Glastron Oil Change Kit For Glastron 187 GTS
Fitter0104
Glastron
GTS
Need help finding what kind and where to buy a oil change kit and filter for Glastron 187 gts. Also need to know where and if I need to change wear ring. If I just need to get these parts on Amazon and it's the same as a jet ski please let me know. I've seen full oil change kits but didn't know if it's the same. Also does anyone know how to order parts for these boats. I need a new bolster mine cracked. Thanks
BobbyP
Glastron
GT
For parts, I use the parts breakdown on Glastron website, then I use local dealer to order. What year is your boat?
BobbyP
Glastron
GT
For engine oil:
BobbyP
Glastron
GT
In cas you don't have this: new in 2016.
Fitter0104
Glastron
GTS
Thank for help. The boat year is a 2014. I wish there was a way to order boat items instead of through a dealer. The dealer by me is terrible.
Does anyone have problems with the rope constantly popping off of eyelet when toeing a tube. It seems like a bad design.
Bill D
Prairieville, LA
If you google XPS oil change kit, there's more than a few out there. Mostly labeled SeaDoo, but should be the same engines. Just find the one that corresponds to yours.
genwrx
Houston, Tx
Glastron
GTS
Might try searching for a shock tube for the rope. I haven't tried one yet or towed any tubers but haven't had any issue with ski ropes and skiing or hydro slide board
Phil A
Bellaire, MI
Glastron
GT
Totally agree on the lousy design with the eyelet. We ended up making a small knot in the loop of the tow rope. The smaller hole and bulk of the basic knot did the trick.
