SWAG GPS Antenna Cover Replacement - White JetBoaters.net Logo
This is a replacement cover for Yamaha part number F2D-U8K1L-00-00 also known as SANAV part number GM-88U.
It is a new design that includes an optional external seal. If you do not wish to use the external seal it is recommended to use silicone caulk to seal between the plastic case sections and around the heads of the screws. It is printed from PETG plastic which should hold up well to sun exposure and resist impact.
To order click the "Buy now" button in the top right corner or click on this sentence which will take you to PayPal.
Nano3
195S
Can this work for my 21 Yamaha 195s
georgia8
Good evening, can you overnight the cap if I pay for overnight delivery? Would like to buy 2 white ones. Thanks.
I could send the covers via overnight shipping for Saturday delivery but it would be expensive. Send me your full address if you want a quote.
My suggestion would be to remove the GPS module for the weekend then reinstall once you receive the covers in the mail. Remove and save the four screws that hold the electronics to the base. Disconnect the multiple wire connector then cut the black ground wire.
LaPlante01
I need this for my 2020 AR240. I think the part number is F3F-U8K1L-10-00. Will this work for that gps as well?
And, can I pay with Zelle or Venmo instead of paypal?
anmut
Are you able to make these in different colors at all?
