GTS 187 impeller and wear ring parts numbers??????
BobbyP
Glastron
GT
You noted you got a 159wear ring .when I called solas, gave them my part number off my stock impeller, he told me it was a 161mm .
Jeff what year is your 187? The reason I ask is if you have a 2014 then you have a 161mm. I just changed mine. In 2015, it went to 159mm.
Jeff85
Nd
Glastron
GTS
It's a 2014 . Wonder why they changed it!? Finally got the right wear the third time...... Same impeller and wear ring the 300 hp sea soo skis use .
BobbyP
Glastron
GT
Not really sure why they changed it. It took me a minute to find too. I found a place to order spare parts....Crowley Marine. Enter in the engine model number of your boat. It should be “440000AAA” , but check the plate on your motor. Choose “AA” for the year and you will get all schematics.
mzuppa
Glastron
GTS
Wow, great stuff here guys. Anyone know of a good dealer/service center in the Tri-state area? I am in NJ and there is literally no one willing to work on the Glastron GTS 187. If I knew it was going to be this hard to service I would have bought a Yamaha!!!!!!
Jeff85
Nd
Glastron
GTS
I'm in North Dakota, but any ski Doo dealership will service them. My only problem was finding a dealership that can read engine codes when they are thrown. I ended up having to go to a scarab boat dealer for that. Their jet boats use the same computer as ours.
BobbyP
Glastron
GT
Top Bottom
