Hydrophase Ridesteady GPS Speed Control JETBOATERS.NET Member Discount, Jan 2021
ericoask424
Kasson MN
Anybody have a picture mounted on a 2020? Just curious if you used the bracket mounted or drilled a hole somewhere? Thanks
Ridesteady
Austin, Texas
Thanks for the inquiry!
You can search our customer install database to see different installs. Check here for some AR240 customer installs: Search | HYDROPHASE LLC
anmut
212S
I went with the external box instead of cutting in the dashboard. Mounted the "arm" bow-side to the engine controls, then adjusted the knuckles so that the box floated just port-bow side of all the controls. Works great - as I power up (or my wife when I'm behind the boat), your hand then naturally goes to the RS box to start dialing in the speed.
white2kstang
Austin Texas Area
I used the external unit and bought a Ram suction mount so I didn't have to put screws in and so that I could move it if needed. I placed it so I can spin the knob with my hand still on the throttle.
WTFover
So If I buy a single engine model, can it ever be retrofitted to a twin engine model in the future?
gallobg
MasterCraft
Here’s mine mounted into the dash of a 2019 AR195. The hole wasn’t fun to cut but I wanted the clean look and it’s easy to reach while underway. Single best upgrade I did to the boat.
suke
Holly Springs, NC
Received mine on Friday. That was fast! I brought the boat back from the dealership this weekend, but didn't really have any time to mess with it. Hopefully we'll get a warm snap one weekend and I can get it knocked out.
Rooster585
Arrggg…..just missed the group buy. Will submit the install tho. Everything looks great, I have to finish a re-model then install the Ridesteady. Can't wait!
JohnB
NE Ohio
I'm planning on buying for a 2020 AR240. What works best for the display - both accessibility and aesthetics - the 4" round or the rectangular external?
jthackman
DFW
yeah, i've been trying to decide also....i haven't seen an install on a 19' ar240. there are two 19' 212x customer installs on the ridesteady site, i guess those are pretty close to the same dash (7" connext screen and phone holder, no round gauges), and both have the external mount on the right side of dash. and i guess that keeps in easy reach after setting throttles.
marcham
Comox, BC
AR195
I purchased a ram mount and backing plate. 4 little holes.
Ridesteady
Austin, Texas
Thanks for the inquiry @JohnB!
You would need the rectangular external display unless you plan on drilling a 3.5" hole somewhere to put the round in-dash display.
EDIT: Updated to reflect 2020 AR240 doesn't have round gauges.
