Reverse module Failure need replacement
Cliff2
Chaparral
VRX
I don’t want to step on anyone’s toes but I fix these on a core trade bases, jetski use the same .
what about the electronic side of it?
was getting the code u0410, checked my connector and continuity in the white/red and white/black wires. tried using BUDS to read the module, per the installation instructions. nothing. pulled it and opened it up, found this. if you look at the chip in the lower right corner you see some sort of blistering, and blackening of the circuit board where that portion of the chip attaches.
boat owner had apperently hooked up the wires backwards at the battery, fried the engine bay harness. after replacing that and getting the motors running again, no shift. medallion displaying e-reverse module error.
the medallion override function doesnt work, but having a communication error code probably causing that.
part numbers supplied in this thread all seem to be superceded. 463081 seems to be the current one, list price is $814.49. and its backordered...
DrMick
215 ID
So excited! Got my replacement reverse module this weekend. Can anyone tell me how hard it is to swap out? I'm sending the core back and get a credit back. I'm so happy with the quick ship fro BRTparts!
Hey mate can you tell me the model number for the reverse module as I need one for my Scarab 215. And also where can I buy it from?
Thanks a lot
JetTech72
SeaDoo
Challenger
Contact Karen@JerseyJetBoats 862-221-0717 She will be able to help you out
Mrhonnesty99
255 G
For future questions yes we service the logic board also
SCARAB1
255 Open ID
Found out today on the water my IST module failed, out of warranty now so it’s on me, I checked the fuses and relay both good, I could here a humming or noise from the IST but no movement.
Disconnected the bucket cable it moved free still no movement
So all is left it the module I opened up the water sealed module to find one for the brush holders had broken off inside the small electric motor.
So now I’m in search of a new module and wondering if it is a swap and replace or does the dealer have to be involved to sync it or calibrate it? Truly unfortunate when it’s perfectly fine besides the electric motor within that failed.
Any one know the price of these, and if it’s a like for like swap and go? Trying to not be stuck on shore for the last big weekend of the year.
Your one of so many scarab owners with INR issues! Contact me! Sailortrawler@gmail.com
Deadon512
HO Impulse
I am having a reverse failure, if I send you a video could you tell me if the issue lies with this unit? I have a 2016 scarab 195. Seems when I hit a little rough water or a wake it Throws a reverser error
FTM3
215 ID
In need of advice I have on that will pull in to forward but not go out to reverse
FTM3
215 ID
Does anyone have the cross number for brp these numbers are scarab but the same part is used on sea doo
