Rotax 250hp engine alignment?
Kyle Mekulik
Newburgh New York
Glastron
GTS
I have a problem where my motor mounts are bad and letting the engine move enough to let my driveshaft and impeller to separate and slip. I have everything to replace and I even have the SBT engine alignment tool. How do I mount the plate to the the pump bolts on the back of the boat. My boat has the driveshaft protector that covers the shaft most of the way to help stop problems with ropes.35B9E530-0586-49EE-9571-09B2144A6AD8.jpegA056F3A6-2C09-4AD0-8EA6-484FF90B8AFB.jpeg
hvluve
Glastron
GT
You should do a video on fixing this problem so other can learn from it :)
Ronnie
SF Bay Area
@Kyle Mekulik , Have you checked you tube for DIY videos? There is a good chance that someone else has already had and solved the same problem.
