Service engine flashing
Briwhy
Saxonburg PA
Glastron
GTS
I hit the 24 hour mark on my Glastron gts207 and the service light came on. Is this just part of the break in period? The Boat is running awesome but the message just flashes across the screen. If this is nothing to worry about anybody know how to clear it?
genwrx
Houston, Tx
Glastron
GTS
Briwhy
Saxonburg PA
Glastron
GTS
I only put around 15hrs on it last season and it was towards the end of the season so I just had the oil changed and everything lubed before it was put away for winter.
JetTech72
SeaDoo
Challenger
Rotax engine Maintenance counter is currently set @ 25hrs for 1st service.
So if counter has not been reset when you did the end of season last fall, then this is why the message would be displayed.
jgiovino
Melbourne FLorida
Glastron
GTS
I have a problem 2014 GTS207 and my gauge cluster reads "CHECK ENGINE" do you actually have a service light. I am desperately trying to grasp for any additional information.
If yours reads "CHECK ENGINE" how many times does it flash?
Do you have an ear piercing tone every tone you turn the key to on?
Briwhy
Saxonburg PA
Glastron
GTS
Mine reads service engine and it reads across the screen solid until I hit one of the buttons and it clears for a few minutes then comes back on. An yes Everytime I turn my boat on it has a loud beep then goes away. That part is normal on these boats. How many hrs are you at?
Jmod86
Southeast, Mi
Glastron
GT
The rotax owners manual says you need to take it in for a "Mandatory" 24 hr inspection. There is a page the dealer/Mechanic has to sign off on. I bet if any warranty repairs are needed they'll be asking to see the signature before they cover anything.
Briwhy
Saxonburg PA
Glastron
GTS
QUOTE="Jmod86, post: 178269, member: 5075"]The rotax owners manual says you need to take it in for a "Mandatory" 24 hr inspection. There is a page the dealer/Mechanic has to sign off on. I bet if any warranty repairs are needed they'll be asking to see the signature before they cover anything.[/QUOTE]
My dealer called me today and said they did all the oil changes and all the maintenance before winterization but forgot to reset the maintenance reminder in the computer. Told me not to worry as it is a 2 hour drive for me for a 5 minute process of resetting it.
Captain Joe
Glastron
GTS
Same problem with my 2017 Glastron GTS 207. Got a group of friends expecting a lake trip this weekend. Haven’t been able to get to the dealer. Boat seems to be running fine. Figure it’s safe to make a trip before getting the service engine light taken off. Any thoughts or suggestion?
genwrx
Houston, Tx
Glastron
GTS
If it's the 24 hour service, you'll be fine but it will beep a lot....
JetTech72
SeaDoo
Challenger
If it's only the Maintenance Required warning, that's like your oil change reminder on your car, you can still drive it like you stole it. Just do the maintenance (Oil filter & check) when you have a chance. Now on newer model it is set at 50hrs for 1st maintenance
pjames
Glastron
GT
Hi, new to this forum. I read the items that imply can't reset the required maintenance or maintenance required light without going to dealer that takes 5 minutes. Dealer charging up to $129 in my area??!! I changed oil, filter, plugs myself and works great but the engine light comes on...isn't there a way, me, owner can reset like an auto oil change light? Please help as I feel system is beating up on little guys that just want to go boating and enjoy.
genwrx
Houston, Tx
Glastron
GTS
unfortunately, i don't think there is an easy way. if i remember the computer you need to do this is a lot more expensive.
