Fargo007
- Pensacola, FL
Watching myself after reading this, you are spot on.you need to straighten and lower your shoulders, thereby you can relieve the stress on your biceps and triceps. Load the board with a little more heels, shifting the center of gravity a little back and outward, now you have a very forward centering, because of this the board dangles along the course. The torso is turned, you ride sideways on one side of the body, without loading the other.
The first thing you need to try is to stand up a little more comfortably. You're just not comfortable. Lower your arms, the handle of the cable should be at your outstretched arms near your waist, your shoulders should be turned (not slouched) and lowered. The load from the shoulders goes through the torso to the pelvis and hips. Your thighs are your strongest and most resilient muscles. If you hold with your back and press, you will quickly get tired and have poor control. The hips are fast, they are used to maintaining balance, they hardly get tired. Load your heels, load your board, move your center of gravity/pressure point lower down your body from your chest (like now) to your waist.
Yes, I'm very uncomfortable, pretty much thanking God every microsecond that I've not wiped out. We're going out again Tuesday and I will work on this. My focus is gonna be on all this stuff, mostly getting more upright with the handle down by the waist and leaning against that line.
Really appreciate it. Thanks.
