Cambo
- Long Island
- 242X E-Series
I took a wrench and unscrewed the zerk put some weed line in and it was dry. Then used a syringe and injected some grease ,it was thinned out enough so that it could be sucked in the syringe. Filled it with pressure until it would push back so I felt like that was enough. Has anyone unscrewed the zerk after pumping grease. I would like to know if any flows out Is the zerk in to keep the contents under pressure similar to how the bearing buddies work?
