1996 sugar sand heat 2 stroke oil?
Accipiter
Sugar Sand
So I just bought a 1996 sugar sand heat jet boat and I know it’s a two stroke engine but I’m not sure wht type of oil I need to get for it. Is there anything specific it needs?
tdonoughue
The Woodlands, TX 77381
Never had one, but I would think that normal 2-stroke oil would be the stuff...
Bilmon
freeport il
Sugar Sand
Mirage
the MFM is correct, any TCW3 rated oil will work
biffdotorg
Pelican Rapids, MN
If it has the original engine, the info above for the 1996 SugarSand is correct and any TCW3 will work. Quicksilver Premium is just fine.
Many motors puked and were replaced by newer Sportjets. Newer vintage Mercury sportjets like the Quicksilver Premium Plus oil. As stated above, any TCW3 oil should work. That being said, there were SugarSand boats that were build with a Mercury Optimax engine. In that case, use the Quicksilver DFI oil, as standard two stroke would be a no-no.
Open the hood and tell us what you have in there? The most common was the 180/240 EFI engines. (Quicksilver Premium Plus) If it was the 200/250 Optimax (Quicsilver DFI only)
Good luck, from the frozen homeland of SugarSand Marine (back in the day) Fargo, ND.
Accipiter
Sugar Sand
C385AA36-D181-4C3A-89FF-8CCAEE5FC298.png This is what sticker on engine says
Bilmon
freeport il
Sugar Sand
Mirage
looks original, that motor was based on the Force outboard. I would go with a TCW3 at 50 to 1
Accipiter
Sugar Sand
Would two stroke outboard engine oil not work?
Accipiter
Sugar Sand
Nvm just found two stroke that is tcw3 sorry I’m new at this. What do you mean by 50 to 1 that seems like a large difference of oil to gas?
the MfM
Do you have oil injection?
(A separate tank for oil) -some take that out and run ore mix at 50:1.
Bilmon
freeport il
Sugar Sand
Mirage
As far as I'm aware those were all carb. motors. Yes 50:1 would be 16 oz oil to 6 gal gas if I remember correctly from my old outboard days, should be a chart on the container. That may not sound like much but it is more than enough at low rpm hence the smoke at idle and the nickname "2 smokes". For reference my injected engine varies from 120:1 at idle to 50:1 at WOT
Accipiter
Sugar Sand
Yes there are two separated tanks for fuel injection makes sense now thanks!!
Bilmon
freeport il
Sugar Sand
Mirage
Ok, I was having a brain fart thinking you needed to pre mix. Just fill your oil tank with oil and your good. Make sure there is no air in the system if it had been run out and be sure the caps are tight. It uses crankcase pressure to feed the oil to the pump
Accipiter
Sugar Sand
Does anyone know by chance an estimate of the mpg on this motor?
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
Don't think you need to worry about miles per gallon rather smiles per gallon. :D
Accipiter
Sugar Sand
Ha ha love it but still don’t want to get stranded if I don’t need to
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
No Gas gauge?
Accipiter
Sugar Sand
Still working on making that part functional.
Accipiter
Sugar Sand
Hey so compression on the motor Are
1-130
2-150
3-150
4-125
What are your guys thoughts on this?
