- Ottawa, Canada
- Scarab
- 165 G
What @Cobra Jet Steering LLC in general are all good things to do regardless. But if the boat was running fine a month or so ago, it's unlikely it's stale gas, etc. Unless you somehow got water in there yourself due to X.
Every time you turn on the ignition, your pump should turn on (you can hear it if you listen carefully). No need to turn on the boat. It lasts 2 seconds. Worth listening too.
In short, it really sounds like it may be a mechanical/electrical failure that's new then if the boat was running fine in January. But ground checking as was mentioned is a good thing to do for sure.
Also, I'll PM you some extra service manual yelp.
