2021 195s Paint Color Code
portlandbucfan
Spokane, WA
195S
Does anyone know the color code for the gray of the hull for the Yacht Blue/Gray 195s.?
Thank you!
mcmspark
Cleveland OH
195S
I think you mean the gel coat color. My 2022 195s is in the shop for a gel coat repair. I can ask them for the color codes when they call me, on mine. (Mine is Yacht blue, but I can ask about the gray)
Hoyt
Suffolk, VA
Suede grey is yamaha grey
mcmspark
Cleveland OH
195S
@Hoyt is correct. The color names are the only thing you need.
only puzzles are Gel Goat, Flow Coat, or Repair paste. Depending on what you are doing.
Gel Coat does not cure in presence of Oxygen, so you need to cover the area with a plastic film for curing.
Flow coat you need to sand in-between coats to remove the wax layer. Repair Paste is expensive, but for small areas it works.
