2021 212 series folding tower height above windshield
Stischendorf
Lake petenwell, wi
I have a 2015 sx210 now and thinking about looking (maybe in a year when they are available haha) for a 2021+ 212 series with the folding wake board tower. But I'm concerned about the height when folded down. I have my sx210 on a boat lift with a canopy so I'm wondering about high above the windshield the tower is when folded. Can anyone help?
Thanks in advance.
SCP1
DeForest, WI
212S
I just looked, I don’t have any pictures, The next time I pull it out of the garage and put the tower down I will take a few pictures.
yall_mahaw
Central Texas
212SD
Not exactly what you are asking for but... if you go to Yamaha's page on the boats and look at the full specs for models, you can see that the SX210 has an on trailer height of 7'4" and the 212S a height of 8'5". Using those figures, you can most likely safely assume and a little over a foot difference in heights while on the lift.
Hope this helps.
tkeru408
252SE
tkeru408
252SE
No, I extended the cables.
That's what I thought, makes it nice that it's just barely above the windshield.
leemo
212X
Any advice on extending the cables? Is there an OEM replacement cable, or did you have to fabricate it?
MikeTX
Lake Livingston, Texas
212X
Any info on extending the cables would be much appreciated. Waiting on my 2022 212XE and clearance into the garage is also a concern.
leemo
212X
Mine folds to about 92”. I’ve been blocking it up without the cables as shown. Cables are disconnected.A684A176-82E7-452D-86D4-04A4DF9799E3.jpegE325AFB1-0DFD-419D-AFE6-F6F258488B32.jpeg
RobbieO
Sacramento River Delta
212SE
SCP1
DeForest, WI
212S
The next time I get up in my boat I will get some pictures. I found a machine shop that had the identical cable and was able to add some cable (fuse them together, I know this is not the right terminology he used but he stated it was better than just soldering them together). He stated it is as strong as the Cable itself (not sure about that one, but looks good and does the job). One other bonus I have is once in the garage I have enough height to put the tower up, so it’s only down when taking it in and out of my garage. A couple things to keep in mind, based on trial and error. You need something to be almost no bigger than the cable, or it will catch and be a pain to use (the other problem is if you use a threaded extension it won’t work on the port side due to the hose in the area - or at least no well). Hope this helps it took me a long time to find a place to do this.
RobbieO
212SE
AZMark
Phoenix, AZ
Veosys
212XE
Hi! I made a longer cables for my 2021 212xe in my garage by myself. I attached few photos.
I bought everything from amazon.
Amadget Stainless Steel Wire Rope, 316 Marine Grade Cable Railing Kit, Aircraft Wire Rope & Picture Hanging Kit for Railing, Decking, DIY Balustrade, Boat Marine Hardware (1/8" x 33 Feet) https://www.amazon.com/dp/B07V3P58JV/ref=cm_sw_r_cp_api_glt_fabc_KFSBCPGEGW6KBWQGGJEN?_encoding=UTF8&psc=1
Muzata 10Pack Hand Swage Tensioner Fitting for 1/8" Cable Railing 8x8 6x6 4x4 2x2 Wood Metal Post System Threaded Terminal Stud End Hardware T316 Stainless Steel Deck CR41, CA6 Muzata 10Pack Hand Swage Tensioner Fitting for 1/8" Cable Railing 8x8 6x6 4x4 2x2 Wood Metal Post System Threaded Terminal Stud End Hardware T316 Stainless Steel Deck CR41, CA6: Amazon.com: Tools & Home Improvement
Loos Cableware SL11-4 Stainless Steel Crimping Sleeve Set for 1/8" Diameter Wire Rope (Pack of 5) https://www.amazon.com/dp/B0038YY2OA/ref=cm_sw_r_cp_api_glt_fabc_19B2ETQ42XN6MFR64D44?_encoding=UTF8&psc=1
CKE Upgraded 10 Ton Hydraulic Cable Crimper Hand Tool for 1/8, 3/16 Stainless Steel Cable Railing Fittings - Heavy Duty Head with 9 Dies and Cable Cutter https://www.amazon.com/dp/B08D3KZCGR/ref=cm_sw_r_cp_api_glt_fabc_N622HAQH5SZQ6B8VVVGY?_encoding=UTF8&psc=1
Veosys
212XE
I still have all tools and materials. If somebody needs it, I can make a new cables. It's easy when you did it before.
SCP1
DeForest, WI
212S
Do you have the tower folded down because of clearance issues? I read in my owners manual (I think) that you should store the boat with the tower down. I left mine up in my storage (indoor)
I only put it down to put it in and out of the garage. Once in the garage I put it up.
