2021 Rotax 1503 4-TEC Factory Service Manual
ramcorpsr
Does anyone know where I can get a hold of a Factory service manual for my Rotax 4-tec model 1503 on a 2021 HewescraftRiverRunner200. The closest dealer to my location is 1000 miles away looks like I will have to service my boat myself.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
I may be able to help. Check your messages.
Frankwho3
165 ID
Hi Luc, Can you send me the manual as well? First time boat owner, 10 hrs on the Scarab 165ID and just got the P2245 error code. Do I leave it, fix myself, or go to the dealer? Thank you!
Frankwho3
165 ID
Hi Luc, Can you send me the manual as well? First time boat owner, 10 hrs on the Scarab 165ID and just got the P2245 error code. Do I leave it, fix myself, or go to the dealer? Thank you! I have a 2021 also.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
O2 sensors are very easy to replace. Just google it for a Sea-Doo. YouTube has many videos.
Frankwho3
165 ID
Hello! So I replaced the O2 sensor with the recommended GM part. Got it out and new one installed with no problem. I started the boat and error code is still there as well as the engine light. I remember reading light may still be on for a few engine cycles but the code should clear. Am I mistaken ? Should I just go out and drive it a few times? Thank you!
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Some codes require software, but I believe this one will clear itself after some engine run time and cycles. As we discussed, it won't affect anything. So boat away and after a few hours of engine run time, if it won't clear, you can either hide the light electrical tape (lol), bring it to a dealer to clear the code, or get your own software to do it (Candoo Pro or BUDS home use). But I think it will clear itself.
Frankwho3
165 ID
Sounds good!! Thank you again!
