255XE—How to disconnect surf point and or do manual mode for the boat
paulg1989
255XE
Hi Guys ,
look story short last weekend someone left the ladder down, and it snapped off my steering plate ,
lead time is a while But what it’s showing when I go to reserve is it’s connecting to surf point , so I’m either looking to disconnect surf point or run in manual mode as the boat won’t leave the lift. As it won’t drive forward to in reserve
Cambo
Long Island
How did the ladder crack the rudder off ? Did you back up and hit something? I'm only a little familiar with that model and Surf point, that I know of is more for the set speed and take of mode slow medium or fast. You do have hydraulic steering could it be noticing some type of resistance due to damage from the rudder being cracked off ? Is the steering stiffer than it was before the incident? Try pulling the battery cable off to do a soft reboot. The rudder may have some type of alignment with the jet nozzles and it could be knocked out of calibration. Some members have removed that rudder on older model boats
paulg1989
255XE
How did the ladder crack the rudder off ? Did you back up and hit something? I'm only a little familiar with that model and Surf point, that I know of is more for the set speed and take of mode slow medium or fast. You do have hydraulic steering could it be noticing some type of resistance due to damage from the rudder being cracked off ? Is the steering stiffer than it was before the incident? Try pulling the battery cable of to do a soft reboot. The rudder may have some type of alignment with the jet nozzles and it could be knocked out of calibration. Some members have removed that rudder on older model boats
Thank you I’ll go try to do that shortly and let you know how it works!
Ill also try to take off the Rutter I took off the tie bar that’s was hanging off the jet that’s connected to the Rutter but I’ll try both
paulg1989
255XE
