8inch Skar Tower Speakers
KCAR250
In case anyone is curious I found some tower speaker enclosures that fit Skar 8” speakers really well. I also bought 4 6.5” and another pair of Skar 8” along with a Wet Sounds 12” sub. Powering them by a 4ch 150x4 and a 5ch 80x4 350x1 NVX Amps, 12 gauge OFC speaker wire, 4 gauge OFC power/ground wire and a 5ch LOC (going in an AR250 so needed the LOC since there’s no RCAs).
My last boat had all JL audio so I’ll compare, post back and see if saving $4,000 was worth it or not.
Wrecked Rooster
Ada, Oklahoma
Definitely curious how this comes out, as my original plan was to go with Skar speakers and NVX amps. Switched to Kicker speakers along with a Kicker amp though. Still working on the install in what little spare time I have.
212s
1000 Islands
212S
Check those speakers - many Skar speakers are cheap paper cone drivers - junk for marine environment.
If you had JL, you're not going to like the Skar unless you're tone deaf. There's a reason they're so inexpensive.
KCAR250
I’ll let you know how they sound once I get them installed. My last boat I put in M series 6.5s with a 10” sub. I’ve heard the paper thing I’ve also heard people comparing the sound to JL so we’ll see I guess. If nothing else I’ll replace them in a few years. JL just keeps raising their prices. The same setup would cost $6,000 if I went JL. That’s almost the price of a SeaDoo Spark.
Wrecked Rooster
Ada, Oklahoma
One thing to be careful of (I learned the hard way) is the Skar 6.5" speakers are not a standard size 6.5. They are larger and require a larger cutout. I was somewhat forced to jump to 8" speakers in the stock locations to cover up the large hole left by Skar's. Was originally going to go with 6.5 Kickers but they were quite a bit smaller then the hole I cut for the Skar 6.5's. Overall, I think I'll be happier with the 8's anyhow.
KCAR250
I knew that from doing some research which I’m fine opening them up. Overall how do you like Skar speakers?
KCAR250
Never mind, I see you went with kicker.
Wrecked Rooster
Ada, Oklahoma
I ended up selling them. I had 4 of them hooked up to a 75w/channel 4-channel amp and they sounded fine. I'm not a big audio guy. But feel like I'm turning into one now...
My2ten
Did you get these installed? Curious to know how they sound.
KCAR250
I actually never hooked them up. I found a deal on Wet Sounds speakers and returned the Skar speakers. I bought Revo 6 for $289 and revo 8s for $379 per pair along with a revo 12 for $350. That being said Skar was great to work with and the speakers seemed like quality.
jwilliams417
212S
This man speaks the truth. My friend came over after installing his "1000w" Skar amp and skar 6.5's and towers to listen to my lowly Kicker 8" towers and Kicker 600w 6 channel amp powering the factory Polks/Kickers in my 212s....his first reaction was "WTF! You have less power and mostly factory speakers, it sounds way better than my full Skar system." I can get mine twice as loud and clean than his, we sat them side by side. Give those Skars some volume and then get very thin and tinny sounding if that makes sense. Buy once, cry once.
tabbibus
Lake Lanier, GA
Goodness, what a deal! Where did you find that!?
KCAR250
I went to creative audio and bought the revo 8s and 6s refurbished however they have since raised their prices to $479 for 8s. That being said the website I bought my revo 12 at has them listed new for $450 for 8s and $350 for the revo 6s, see link.
SCP1
DeForest, WI
212S
Do you have a sub? Thinking of doing something similar, any thoughts or recommendations.
212s
1000 Islands
212S
For good bass response a JL M3 or WS 10" IB sub is what I'd recommend at about $350. If you want to keep costs down, a 10" Kicker IB sub is $200 and will give you decent bass. Hole saws are available on Amazon to cut the opening for a sub if you want to go that route. Note that if you change your mind and want to upgrade to a 10" JL sub, the cutout hole will be too large. For instance, a JL 10" sub uses an 8.85" cutout while the 10" Kicker uses a 9.1" cutout, and the WS uses a 9.2" cutout. So choose carefully.
One of their TB tube subs will give more impact if big bass output is what you want, and no need to cut a big hole to mount it. But ideally you need to install it somewhere in the open, like under/behind one of the bucket seats. Putting it under the bench seats out of the way will muffle and cut bass impact a fair bit.
Lots of options to look at.
SCP1
DeForest, WI
212S
Do you have a picture of your tower speakers, trying to decide between the Kicker 8”s or the Kicker 9”. Can you hear the 8’s surfing?
