Battery (hopefully) issue
LeeFlan7
Bucks County, PA
Hi all,
Looking for a little guidance here if anyone has insight.
Ive not used my ski so much this year as we have the 18 month old on the boat.
Over the weekend I rode the ski after I had to start it with a jump box...well, after my wife took her turn and turned the ski off I could not get it going again even with a jump start.
All I could get was a slight "whur" and some clicking...Im hoping my battery just needs to be replaced...but any insight would be appreciated.
The ski is a 2015 V1 Sport with the MR1 engine.
Thanks!
Neutron
New Bern, NC
Start with a new battery. Sounds like typical symptoms
LeeFlan7
Bucks County, PA
Thanks for the reply, I’ll pick up a battery tomorrow and check that first!
Neutron
New Bern, NC
If you have a voltmeter, check standing voltage then recheck after you start up. Make sure it goes up to like 13.5 volts or higher. If it drops lower than your standing volts, you have a charging problem
LeeFlan7
Bucks County, PA
Thanks for the input...seems like a new battery has solved it for now
