the MfM
- Other
- Other
- Other
Symptoms
Port Engine stalled at high speed
Checked safety switches and found rear hatch wasn’t locked
Ran it again and it was fine at idled but stalled at high speed.
This time it wouldn’t turn over.
Let it cool down and it turned over and started.
Figured it was may be lean seizing and or blocked cooling.
Checked Plugs and found the #3 plug had no gap.
Also could see the top of the piston was dented.
Zero compression on #3
So I pulled the engine yesterday.
...to be continued
...to be continued
