Fuel type used????
tomfoolery
Cambridge, Ontario Canada
Glastron
GT
What grade fuel and or additive are you using?
87 / 91 / 93?
Jr15g
Richmond Hil, GA
252SE
scokill
Rowlett, TX
I would use what the manufacturer recommends. You are wasting money otherwise.
tomfoolery
Glastron
GT
I have read on Scarab forum that 89 was ok for 250hp jet even tho fill able says 91+.
Big Shasta
Panama City Beach, FL
Use what the manufacturer recommends. It's mostly based on compression ratio. Higher ratios (or forced induction) need higher octane to prevent detonation.
Jmod86
Southeast, Mi
Glastron
GT
That was one of my questions before I bought the boat. The sales man told me it takes reg 87 but should use a ethanol additive. I haven't picked the boat up yet (3 more days!) so I haven't been able to read the books on what rotax recommends. Anyone with the boat should chim in soon, Hopefully
genwrx
Houston, Tx
Glastron
GTS
I'm running shell 93, curious as to others thoughts...my salesman didn't seem to knowledgeable on it. My WRX STi is runs way better with 93 than if I have to use anything less, so my current thinking is if it's boosted with a supercharger or turbo charger, I'm gonna use 93
Devin Jensen
Island heights nj
AR192
I use the highest they have (usually 93) with my ar192... i figured it can only help out performance and long term reliability
waterboy
Holly Springs, NC
almost 10 years on the cheapest 87 octane pump gas with ethanol. 87 is all Yamaha recommends. not that i am a fan of ethanol just do not have other options. Runs great and never a stumble. Put her away in the winter with StaBil and a full tank of gas. knock on wood :)
McMark
Monongahela, PA
93 pump gas
Non ethanol when available.
ravi4l
Indian Head MD
89 in everything i own expt Lotus and Bikes lol
biglar155
Fredonia, WI
I run the lowest I can get that doesn't have ethanol. Unfortunately for me, that usually means 91 ("Premium") at my local station. I found a place that has non-ethanol mid-grade but I wouldn't be able to pull in there without completely blocking off his driveway.
My #1 rule is "No ethanol in the Boat." I think I've had to break that rule one time in 7 seasons - and then I added Sta-Bil even though I was planning to burn most of it off that day.
I know a lot of folks don't have a choice, but if you can avoid ethanol you should.
Big Shasta
It's a common misconception that premium fuel is better for the fuel system, not true at all. Also, the naturally aspirated engines are designed for low octane fuel. You're likely spending money you don't have to with no benefit. Spend that money on the extra it costs for non ethanol fuel if you can get it. If not make sure you're using an additive for ethanol fuel like star tron or stabil for ethanol.
If you can't get top tier fuel then use a good additive for cleaning the fuel system like the chevron additive or seafoam every few tanks.
JetTech72
SeaDoo
Challenger
For Rotax 250 ECT engine, 91+ w E10 will be better than running 87 ethanol free.
You will definitely see more rpm out of your engine, especially in the heat of the summer.
McMark
Monongahela, PA
If you're using 91 or 93 it isn't E10. More like E1. That's why the pump says "up to 10%".
swatski
North Caldwell, NJ
Both good advice, actually!
swatski
North Caldwell, NJ
Can't look it up right now, but I believe it is a fact that the MR1s and 1.8ls N/A engines will run somewhat FASTER with regular low octane with ethanol. Not necessarily the best thing long term, but without knock sensors they surge on low octane.
I must confess to always using premium 93, and it is always the same station (frequented by import cars running on premium...) :D. I know... it is unnecessary, but what the heck, gas is still so cheap.
