Jim_in_Delaware
- Southeastern DE
- Boatless
- NA
- Other
- Other
The conundrum becomes, however, how are we planning to use the vehicle? For a people hauler, perhaps the larger battery isn’t necessary. If one is going to tow with the vehicle and have a 1/3 loss in range during towing, perhaps a larger battery is necessary.In the same regard, bigger batteries aren’t the correct solution to long distance driving. Because they take longer to charge it can be quicker to get to a destination in an EV with a standard battery that requires three stops to charge vs an extended range EV that only requires 2 charging stops. The extended range EV is then also unnecessarily hauling that bigger, heavier battery around everyday.
Jim
