sunbyrned
- Louisville, KY
- 242 Limited S E-Series
I got into a situation where I can’t manually winch the boat any longer. @GTBRMC recommended installing an electric winch. Wonderful idea! I thought it was going to be a simple transition. Take one off, put the other one on. Nope! Had to cut through the welding to get the cover off the manual winch and then drill new holes for the electric one, so if you decide to do this, give yourself a day. I had to position the electric one closer to the boat so the cable wouldn’t rub against the trailer. Winches are expensive but I found this one for $129.00. It advertises as a marine winch. It only winds up electronically. It doesn’t release electronically. That’s fine though. I just keep it tight like the old winch and then let the weight of the boat pull it out by releasing the tension once I’m in the water. My only concern is that it’s a cable and not a strap. If that thing ever broke, it could do some damage I guess, but I don’t think It’s under a lot of stress. Here’s some pics. Video is too large a file to upload.
