Lost Bimini Pole
D3nN1s
NJ
255XD
Anyone else lose a Bimini Pole while trailering? I ended up finding it on the side of the road a week later but it already had been mangled by passing cars. I looked up the Part from my local dealer (F3A-U3113-20-00) but they want $160 out the door. Its the pole that extends out forward from the bimini and secures to the waketower with a ball on the end. Online stores are a little cheaper but still quite expensive for something so simple. Anyone have ideas or solutions? Besides ponying up the $160 part that is worth 10$
subysti
east Longmeadow Mass
I lost mine in about 80' of water. Found it online for about $110.
D3nN1s
NJ
255XD
Yeah finally ordered a new one, 120 shipped... lesson learned
Paul Strader
Cicero, NY
AR192
Has anyone ever found a canvas maker that could make one? My local guy said he hasn’t been able to get the Ball end because it’s an odd size. He has the tubing and the pop button, just need the end piece.
D3nN1s
NJ
255XD
Wish I would have saved my damaged one, would have shipped it to you
Redneck_4Play
CONNECTICUT
I broke the inner pole that extends with ball socket on my last year. It was sticking out and caught it on the garage. Was floored how much they wanted for a replacement. Found a 2' aluminum pole with same o.d. on amazon along with a new ball end. Cut to size, drilled a hole, transferred spring clip and installed ball end. Can't tell the difference from the factory pole. Cost less than $40.
Paul Strader
Cicero, NY
AR192
Do you have the link for the pole?
Paul Strader
Cicero, NY
AR192
12CB7093-57A9-4F43-9201-EA9D076C7F3D.jpeg Found a local marine canvas guy that was able to get all the parts and is making me 2 of the sliders, I wanted a spare. If anyone else needs this part, let me know and I’ll post his phone number.
Blue Hawaiian
Toronto, Ontario, Canada
please let me know, mine dropped when setting up on the water, it just ran for freedom in deep water, i tried several time with DI but failed, thank you!
Hbjrico
AR195
Do you have any links for the materials that you used or where to find a part?
Hbjrico
AR195
Lost this piece for my Ar195 Bimini
2kwik4u
Georgetown, IN
How are you guys losing these things? I've trailered tens of thousands of miles over 7 seasons now and never even adjusted or moved those things and the bimini top is stowed and trailered attached to the tower.
dan144k
Palatine, IL
I bought the plastic ends and then used a piece of copper. Just cut it to length.
Hbjrico
AR195
after a couple beers, you let friends “help out” when you’re not paying attention bc your doing something else.. luckily I caught that the other one that was still attached, hanging by the ball eye before it too fell off
2kwik4u
Georgetown, IN
Well, that explains it. I don't have friends so I always end up doing it myself :D :D
