Truck4dog
At the end of last season (for me) I had a catastrophic engine failure. I noticed a bottom end knock and chose (poorly) to push both engines back to the ramp. I'm still not 100% sure of the exact problem. The final failure was when the #3 rod came through the side of the block. During the long block installation inspection of the oil pump revealed some gouging and a rebuild kit was ordered and the oil reservoir disassembled and cleaned. The reservoir was full of failed engine glitter and at the bottom of it all is the screen that prevents the metal flakes to be circulated.
My port screen had a nice little hole in it. In my attempt to drain all of the oil, I most likely pushed the suction tube into and through the screen opening the door to large particle contamination of my engine oil and possibly contributing to my engines early demise. I'll check the starboard engine and post what is found.
Please excuse my dirty bench.
