My $500 Aquatrax F12X project
JetPowered
Sunrise Beach Village, TX
Limited
I wish that would’ve held true on their Honda Odyssey. The oil filter was directly above a crossmember which made it pretty much impossible to drain the oil without getting oil everywhere.
sethman919
Apex, NC
That’s ski is looking better and better! Hopefully when you get it out on the water it will give you no trouble. Will you recover the seats eventually?
Where did you get those traction mats?
Had it out already. Ran like a beast but threw a code after about 30 minutes. Oil is still nice and clean. Didnt realize you really need to pull the codes when it happens. Will need another test drive. Bought the mats on Ebay. They're black tips in the blue marble. Dropping the seat off on monday.20190410_181107.jpg
GTBRMC
Waukesha, WI
Very true. My wife drives an Odyssey right now. Unfortunately, the minivan platform drives a lot if packaging compromises (which is an issue for all minivan builders).
/ end threadjack. Apologies to OP.
sethman919
Apex, NC
Dropped the seats off yesterday. They think they will get them done by the weekend. We will see.
sethman919
Apex, NC
Went and got it registered in my name today. Installed new reg stickers and installed a couple custom cut pieces of traction mat to cover up some cosmetic flaws. I also installed a new Jack on the trailer cause the old one was badly rusted.
20190420_144514.jpg20190420_145100.jpg20190425_123414.jpg20190425_123430.jpg20190425_123421.jpg
Evil Sports
91 North/75 South
SS
I really like the seating position on mine, quite comfortable but then again I also stand and ride it to break it up especially if there a chop.
JetPowered
Limited
Awesome! I hope it gives you many trouble free hours! Have you pulled the pump and check the impeller bearings?
buckbuck
Texas
How much $ do you think you have in the project?
Evil Sports
91 North/75 South
SS
Yeah I estimate mine is worth 4-5K and it has been 100% trouble free except when my employees grounded it on the river and jammed the impeller with wood and rocks. That was a pump redo but it was worth it cause it got rid of the cavitation due to wear, with the turbo boost it started getting annoying
sethman919
Apex, NC
I had cleaned sanded and repainted the step brackets over the last week. Just reinstalled them. I also double checked the hours.
sethman919
Apex, NC
Ok guys. Check your Skis hull numbers. All aquatrax skis were recalled for the fuel tank. They are still performing the recall. I'm dropping mine off on Saturday. Apparently if you get certain cleaning chemicals on the gas tank it will crack and leak. I had to call around a lot to find a dealer that used to sell aquatrax and is familiar with the recall. Im having to take mine 80 miles to get it done.
JetPowered
Limited
Yep, had mine replaced this winter.
