my new anchor buddy
Ronnie
SF Bay Area
I've been using them for years and now have two, one for use as designed (I.e., to pull the boat away from the shore) and one as a standard anchor line. I think they are great.
jawsf16
I have one and use it for anchoring in light chop. Never used it as designed. The only caution is never use it completely by itself with a heavy anchor or "catchy" bottom. The stress of trying to free an anchor or pulling up heavy weight on the bungee is a bit concerning.
Ronnie
SF Bay Area
Good point Jaws, I had the loop on one fail (unravel) once. As a result I tie at least two knots near each loop on mine. It sucks to lose anchors moreso when they are pricey like box anchors.
itsdgm
We love our anchor buddies. Keeps the ladies from having to get in the water too deep while boarding.
jdonalds
Redding, CA
I've used the standard (25' stretches to 50') for years. I use it as designed and suggested with a 25 lb. Richter anchor. They work great. I have 150' nylon line too but it has never been in use because the Anchor Buddy is all I need.
The first one broke on the inside surgical tubing so I bought a new one. For $29 I wouldn't have an issue with buying one every year.
Lspeedss
Powhatan,VA. 23139
These are awesome. I have used them for years. Really aid in keeping the anchor in place. Just be sure to clip the end onto the tang in your anchor locker. The "rode" gets short fast as you drop anchor..
Speedling
Cedar Lake, IN
SS
Wait, so what does it do for you? It gives a little less shock to your boat or something? What about tying up with a bunch of other boats around? We usually end up tied up with like 4-10 boats at a time. Would it work for that kinda thing?
jaybro72
st. Peters, MO
they make little ones to tie boats together or to docks
jdonalds
Redding, CA
jdonalds
Redding, CA
The idea and practical use of the Anchor Buddy is this.
Drop your anchor off the bow as you're backing up towards the shore. Position the anchor so that when the Anchor Buddy stretches you can reach the shore, or as close to the shore as you wish to be. Then set a shore anchor for the stern of the boat. You can then enter or exit the boat easily. When you are ready, you let out slack on the shore anchor line as you stand on the shore watching the Anchor Buddy pulling your boat away from the shore. Now your boat is well away from the shore so it isn't getting damaged by waves or wakes banging the stern of the boat on the bottom of the shallow area.
When you want to board the boat simply pull it to shore with the stern anchor line. The Anchor Buddy bow line will stretch so you can pull the boat to shore.
It's easier than it sounds.
The Anchor Buddy doesn't work in all conditions. The boat can sway more with the elastic bow line. If you're in a situation where you have boats anchored close by they won't move the same way your boat does and you can bump other boats. Also there's no way I'd leave my boat (again) overnight on the anchor buddy. We had a strong wind come up and push the bow sideways enough to break the anchor free. That wouldn't have happened with a standard line where I could have given it much more scope. The 50' line simply doesn't allow enough scope.
Another advantage of the Anchor Buddy though is in calm or mild conditions the boat won't e tugging on the anchor constantly because the Anchor Buddy will take most of that action in the surgical tube and it won't be transferred to the anchor so the anchor is more likely to stay set.
For anchoring away from the shore, say in a cove, I always use the Anchor Buddy. Toss the Richter Anchor and forget it.
