OEM cover fail?
blacksapphirez
Charleston, SC
SX195
I used to have 19ft and 24ft OEM covers that i was able to use...like a COVER. but the new 19+ non-tower19ft covers have holes for the bimini top(which I don't want ANY holes ) AND it does not allow for the bimini top to be stored UNDER the cover... WHY?!
I cannot use the cover as is. The cover would not fit with bimini under it. Back in the box it goes
Ronnie
SF Bay Area
Are you sure those are access holes for the Bimini top and not the wake tower?
blacksapphirez
Charleston, SC
SX195
yes...part number is specific to the non-tower (even says on the box and the cover it self)
blacksapphirez
Charleston, SC
SX195
two openings on each side for the bimini top to be stored up... i would rather not!
blacksapphirez
Charleston, SC
SX195
what I want
what i DON'T want
Thermobrett
Lithia, Florida
SX195
My black cover has the bimini up holes. Let’s just the right amount of water and dirt in that you don’t want in a boat. With the cover poles, I am able to drop the sop and cover the bimini. Like you said, the box specifically stated for the SX-195, not the AR-195
blacksapphirez
Charleston, SC
SX195
If you have a pic, let me see how you do it. I couldn't even get the cover on it was so tight!
Judge
Cape Coral, FL
275SD
What part number are you using?
I had a 2014 SX192 and in 2017 I bought the cover that looks exactly like this.....
According to Leaders website, it is showing the same picture.
But I found this one on ebay. It is the same part number as Leaders but ends in -14 vs the -19. The -19 may be the one with the holes for the bimini now. This is the one I bought for my SX192.
How much difference in the SX192 vs the SX195? From pictures my SX192 looks a lot like a SX195 but the length and width may be slightly different.
blacksapphirez
Charleston, SC
SX195
Pictures are misleading as they just reuse them.
Like original post, ive had ones without any holes on top which is my preferred design
Judge
Cape Coral, FL
275SD
I asked in my previous post.... what part number are you using????
I bet this the part number you want... MAR-190BK-NT-14 and not MAR-190BK-NT-19
blacksapphirez
Charleston, SC
SX195
I have a 2020 so the old cover ending in 14 would not work...but would love to see if it will!
Judge
Cape Coral, FL
275SD
I would pull the dimensions for an SX192 and an SX195. I'm betting they are damn near identical. The pictures I have seen of SX195 look almost exactly like my old '14 SX192.
I'm betting they only change in the cover is with or without the holes for the bimini.
Thermobrett
Lithia, Florida
SX195
blacksapphirez
Charleston, SC
SX195
2020 had a hull change... longer (3") and wider(2")
blacksapphirez
Charleston, SC
SX195
ok no anti-pooling poles... I put them in since its going to stay outside at a storage lot. but ok. Its good to know
I also had pool noodle under so it wouldn't rest on the cushion but that may be what is preventing my cover from going on....but its like 1 INCH!
Thermobrett
Lithia, Florida
SX195
I tried not using the poles, didn’t pay attention to the weather, definitely had mosquitoes growing on the cover. Added poles, tighter fit, no bugs.
blacksapphirez
Charleston, SC
SX195
@Thermobrett I see your rub rail is showing... does it affect the cover while driving? all of my previous covers have covered the rub rail... and this one wouldn't
Judge
Cape Coral, FL
275SD
Then your probably SOL since they don’t make it like the -14 any longer.
I have an old grey one that was shot after a couple years that I replaced with the black one. The black one was much better. I’d give it to you so you could try to see if it fits if you paid the shipping… probably not cheap to ship.
But I won’t have acces to the cover to ship it until early May.
Thermobrett
Lithia, Florida
SX195
I only trailer about 5 miles with the cover on when I go to drop the boat off. I also tighten the rackets very tight. I do have a little play side to side so it may be pulled down on one side a little further than the other.
blacksapphirez
Charleston, SC
SX195
I'd pay shipping for it :) maybe $50-60 i'd imagine. i'm in SC. keep me in mind
