Ronnie
- SF Bay Area
- Limited S
While I appreciate having the donor boat for parts and the experience I gained dis-assembling it, I want it gone ASAP!You should keep the boat in the backyard and hack it up to turn into an outdoor bar.
the only things left to remove on the hull that I want are the rudder, ride plates, possibly the clean out plug mounts, the unbroken intake grate, the yamaha symbols and the fuel tank /related accessories. I should be able to remove all of that by the end of next weekend.Looks like the first three items will need to be cut out.
i forgot to take pics along the way but here are a few more of parts recently removed. I removed the rub rail, storing it was a PITA but I managed it. That will be a pickup only item, I won’t pack and ship it.
as far as. I can tell the top and bottom of the hull are held together by some adhesive, possibly fiber glass resin and a lot of screws which secure the rubber of the rub rail to the SS frame and the SS frame to the hull. If Yamaha added any Sound absorbing or extra floatation foam to this boat o haven’t found any.
