Stereo question
Martin005
So I haven't found a 100% answer and just want to double check. I get zone one and zone two on the rca but what is sub out that is orange for each zone. So right now I have the stock 4 interior speakers hooked up by the color coded wires. Do I need to change those when I add tower speakers that will be off of the zone one rca’s? My sub will come from zone 2 rca’s correct. Any input will be great. Thanks.
jthackman
DFW
is it for the stock fusion RA70NSX? wiring diagram attached for it.
if not adding an amp, you won't use those rca plugs.
each orange rca is a mono sub output. will plug into your sub amp, or the amp input channels you're using to power the sub. manual says sub signal is associated with zone 1. i think the fusion app gives you more control of the sub channel, allows you to assoc with z1 or z2.
Martin005
I plan on having an amp for tower speakers and an amp for sub. Yes it is the fusion ra70
