Throttle Dropping? Check here!
Matts18
East Tennessee
It was pretty straightforward. I ended up unbolting the part that has the fork and crimping it on the bench as I didn’t have needle nose pliers with enough leverage. Any tips on setting tension would be appreciated....I am guessing as loose as possible without the lever slipping back?
0627Devildog
Classifieds Moderator
Acworth, G.A.
That is what I did. . . . . Just tight enough so they hold, but move fluidly.
Matts18
East Tennessee
Took the boat out yesterday and the difference is amazing. The throttle is so precise I hardly see the need for cruise assist. Thanks to all for the help.
LKNHokie
Cornelius, NC
Did this last week (before Hurricane Florence) and waited until the rain cleared to test it (couldn't find any friends as brave/dumb as I to go surfing on lake with rain and a little wind...). Works perfectly! Thanks @Speedling, you're my new favorite!
Speedling
Cedar Lake, IN
SS
Glad to hear it and that you didn't get wiped out by the hurricane!
LKNHokie
Cornelius, NC
Thanks, wasn’t much of an issue as forecasted inland. We’re lucky and feeling for those to east.
Zeusmotorworks
Republic of Texas
FSH Deluxe
Necropost... had it with the damn throttles today. Did the fix with tape AND used loctite on the 10mm bolts. Unfortunately it with be Weds or Thurs before I can try it out.
Speedling
Cedar Lake, IN
SS
Hopefully all goes well!
mattster
Carmel, IN
Limited
I just brought home a 2012 242 LTD, and the throttles are driving me crazy (port engine throttle is "loose" on mine as well for some reason--stb. is ok). I'm going to give this a go--if I can get the throttles "buttery smooth" as someone else mentioned, I'm a super happy guy. Thanks in advance for the write-up, neighbor (Crooked Lake, IN)!
Gym
Falmouth, MA (Cape Cod)
Before you tear things apart have you tried tightening the friction screws on the back of the throttle quadrant?
mattster
Carmel, IN
Limited
@Gym, I have, but from what I'm reading here they're 2 different issues. My issue isn't throttle friction per se, it's the RPM drop from the port throttle not staying put--but drifting down in RPM.
Speedling
Cedar Lake, IN
SS
Lol crooked lak indeed. I prefer Lake Michigan but i am actually on my boat for the first time this year on cedar tucky. Need a test and tune ya know? Anyway hope the write up helps and hit me up with any ?
Gym
Yes @mattster the throttle lever dropping back is the issue. Most of us have had this issue. Just wanted to make sure you tried the easy fix first by tightening the friction screw. If that doesn't help @Speedling's fix seems to have helped many.
mattster
Carmel, IN
Limited
there's no doubt I'll have questions! This issue is so far my biggest complaint about the boat. If I can remedy this--jetboat heaven!
I'd love to try the big lake sometime--makes me a little nervous though. I didn't see Dale Hollow (KY) on your list--that's another beautiful body of water.
mattster
Carmel, IN
Limited
after all these years/so many issues, I'm surprised that the factory hasn't come out with a bulletin on it?
Gym
Then they'd have to admit they f-----up.
Speedling
Cedar Lake, IN
SS
Yes it is sorta. I want to visit all the major Kentucky and Tennessee lakes. In fact i want to retire to Tennessee.
mattster
Carmel, IN
Limited
Have there been any updates to your fix, since your original post was a while ago? I guess they'd be in this thread...duh.
Speedling
Cedar Lake, IN
SS
The basic idea is the same. You can pinch the pieces together instead of using tape like i suggested. Ihad done that as a trial and error concept. I still have the tape in there and it works fine. Is that over 5 years now?
GeauxDeep
Spotsylvania, Virginia
So i started on this fix this morning, only got the port side done. i'll do the starboard tomorrow. I'm really not sure that i see that much of a difference just testing it in the garage. also, my drop is so bad that if I'm not constantly holding both throttles in place, they'll basically drop almost all the way back to the first "click' of the forward position. gets to the point that my arm is sore from holding them in place all day. i was wondering how tight the circular part should be on that nylon bushing. i put the electrical tape on the piece inside the fork, but should i tighten those small nuts around the nylon bushing to make it any tighter? or do i need to be looking at the parts under the engine hatch to see if theres something too loose under there? this is by far the most annoying thing that i deal with. hopefully i can solve this and test it friday when i go out.
