Thrust vector install questions for 195S
pnwest93
195S
Hello - I recently purchased the thust vector for my 2021 Yamaha 195S and had a few questions/issues that came up during install.
1. In the instructional video, it was advised to put a washer next to the spring to isolate any tension from the reverse bucket. The kit did not include this washer, is it necessary? Additionally, the video mentions puting the factory bushing on at the end of the stack but at that point the whole stack covers all of the threads so I was forced to install without that final washer and factory bushing.
2. At the end when connecting the steering arm, the supplied bolt is a bit too long and will get in the way of the fin lifting up. The video mentions only tightening the bolt so that only 1-2 threads are sticking out to prevent blocking of the fin but in doing so the bolt appears to be very loose/wobblyDD6A5A68-21FC-4FD9-9A14-AD48DD5A3726.jpeg14CA0E86-411B-4AB4-AAE2-D99AC119E47A.jpeg and just hanging there. Was this the intention or would a shorter bolt that I can actually tighten down be better?
Ozark
195S
I don’t have my service manual with me but the torque spec for the steering linkage bolt/nut is very very low. If you over tighten it you’ll bend the fork on the linkage.
RobbieO
Sacramento River Delta
212SE
Rangerusa1111
I just installed on a set of new thrust vectors on Saturday and had the same exact issue. I believe the bolts I received were both the same size on the left and right side. The bushing for the right side was long. I used that and placed a washer on to isolate the spring since that seems essential to isolate the bucket from the spring. I also dId not, could not use the factory bushing since I had no room left on the stack. I went to Home Depot for a washer. I just used the measurement from the tap size Will mentioned in the video for a washer. I think I used size 8 metric.
On the steering I would push up the bottom bolt and tighten up the eye lock until 2-3 threads are shown. The fin should be able to open freely and the kickstand work without hitting on the steering arm.
fatboyroy
Sebastian, FL
I did not follow directions I think as long as the fin pivot ok I can tighten it as much as I want. See it have enough clearance to pivot pass the bolt 11851F8B-5645-4515-BC9C-1B2977565D0C.jpegD0800F19-B2D0-4B6F-9436-8A986FE8DF20.jpeg
Can0n11
FSH Deluxe
1. The single kits come with the 1 3/8" bushings. I called and had a great convo with Will last week on the addendum which uses the shorter bushings for the larger twin boats. I had access to a larger thin washer that fit over the Rt. side longer stainless bushing which I added between the spring and bucket but hindsight, not necessary.
2. I followed the instruction on the video's recommended minimum thread requirements. The gap is a concern, I may make a 3dp washer if this is an issue later on. I didn't ask if the bolt could be installed bolt head up but the video mentions its installed in this orientation for ease of Mx down the road.
That said, I took the boat out this weekend and all I can say is wow. Tracks a straight line now with little to no effort. Tight turning radius. Pretty sweet upgrade.
Rangerusa1111
Thanks for the 1 3/8 bushing update. I kind of figured that, but glad You took the time to confirm for us. All your input is good info.
