Took my LS2000 for the first time, couple questions
Bruce
Royal, AR
I kept the oil injection system for my year of 2 stroke ownership. It reduces the amount of excess smoke at idle and low speed.
Roof Man
Dallas, TX
LS
Oh, the engines/compartment is very clean ... but, looks all original too. Thus wanting to change the oil lines (or convert now), plugs, possible wires, fuel lines, ... Oh, ordered a fuel/air separator from Group K too.
OCMD
Ocean City MD
No need to convert. The pumps never fail. The lines do so replace them. It is a hassle pre mixing. Measuring oil, wondering how much gas in the tank etc.
bluejetvt
LX
Couple of updates in the past week.
-I installed a new Sony headunit. Seems great though I'm not sure my 20 year old speakers are the greatest test. Updating them will probably come soon. The brown/orange wire I was asking about earlier seems to go to the original remote mounted by the driver's seat. View attachment 123758
-I installed a new horn as mine didn't work, that was super simple.
-I installed all new gauges except the speedo because it still works. The fuel gauge and sending unit were both bad. I was able to fix the sending unit by regluing the magnets to the float. I'm going to add a little warning light to the dash since this new fuel gauge doesn't have an oil light. I replaced both tachs. I also added water temp gauges for each engine with sending units right off the engine. I don't know if they will be super effective but it gives me a little piece of mind that I might catch a problem before it's too late.
I replaced my port side Forward/Reverse cable. It was pretty stiff when I got the boat. I thought it might work itself easier with some use but it was just getting worse and worse. I couldn't tell until I removed it but the stern end was pretty bad. Fortunately I was able to get a new one for less than $50 and replacing it was pretty easy. I disconnected the old cable at both ends then tape the new cable to the stern end of the old cable and was able to pull the old out through the shifter hole while pulling the new with it. There was just one zip tie behind the engine bulkhead that needed removed. That was accessible through the access hole so no reason to remove the cleanout cover. Shifts like butter now.
I also replace the passenger side hub. When I did my first water test 2 weeks ago the trailer barely made the hour drive to the lake. You try to look everything over but I missed that that hub was in bad shape. Fortunately we found a replacement hub at a nearby trailer supply store and were able to replace everything in the parking lot. When I got home I checked the other side and while it looked to be in much better shape, I'm guessing it's original and for $30 I'd much rather replace it now than have a problem later.
Tonight I'm going to get most if not all of my air/fuel separator system setup. Other than some tidying up that is about all I have left to do before I can hit the water.
bluejetvt
LX
I’m curious how your temp gauges ended up working on the Ls2000? I’m wondering if I should do the same.
UnorthodoxCreations
Hanover, PA
I've sold the boat but they were useless. The gauges I had didn't read anything less than 100 degrees or so and the water coming out just isn't that hot. Gauges that read lower might help but I didn't want any gauges that didn't match.
bluejetvt
LX
Thank a lot for the info. You’ve saved me time and money.
bluejetvt
LX
I’ve deci
Here’s what I came up with for the seperators. I also added a #95 jet in the return line tees
I’ve decided to go with this setup, pretty much exactly. How did you connect the return fuel lines? Did you run the fuel line from the mag end of carb rack to the top of catch can and plug off the return lines going back to the tank or did you tie them all together? I’d love any other pictures you might have of your setup.
the MfM
bluejetvt
LX
Perfect thanks brother this is a huge help. I owe you one. I will feel better now protecting my new engine
