Using Anchors Within Posts
Bruce
Royal, AR
Some posts such as Preparing For Bimini use internal anchors to create links. In this case anchors were used to create an index.
To do so you need to use two BB codes.
Rich (BB code):
The first creates an anchor point and the second links to it.
Previously we had implemented this via a discontinued add-on.
It should continue to work in all posts it was previously used in via a pair of custom BB codes.[/POST]
