Wash down pump how to get to
Waterboy57
My washdown hose sprayer cam off fell in water now the hose slipped in the hole it comes out..lol How do I get to the hose to pull it out and replace the spider I can't figure out where it's at exactly is it in the engine compartment that I'm just not seeing it?
chester2008
Brighton, MI
I would start by removing the speaker or cup holder next to the sprayer, mine is a different year but i believe the location is similar. This should give you access to the area where the hose would have fallen. This area is separated from the engine compartment. You may also be able to see it from the clean out plug access panel
Waterboy57
Thanks was able to get to hose through speaker hole! Thanks so much for the info!
sunbyrned
Louisville, KY
Just an FYI. You can access the water container and various aux cords through this side panel inside the engine compartment. I plan to add a longer hose this summer, so this will help.
Waterboy57
Awesome...thanks!
