2021 AR210 code reset
Scottma
Does anyone know if I disconnect the battery for a duration of like 5 mins, would it reset the engine code from the system? or does it require like a code reader of sort to reset it?
Gonzalo
Miami, FL
What do you mean by engine code? I shut off the battery of my SX210 every time I come back from the boating day.
RobbieO
Sacramento River Delta
212SE
If it's an intermittent fault, it may turn off the check engine light, but the code will remain in memory. If it's a hard/current fault, the only remedy is to fix the fault.
