2023 195S
Vem2001
NYC
195S
Need some help . Just purchased less than 2 weeks ago a 2023 195s. Can someone tell me if this is normal or if someone can take a picture of their engine bay . This is below the fuse panel rear wall and floor area of the engine bay . I started to clean the boat inside and out when I noticed this. Thanks
anmut
212S
Hard to say - looks like they f'd up the cut the first time and got it right the second? That appears to be the wall between the engine bay and the exhaust portion of the boat. I'd say it's fine. You could complain but they'll probably tell you it's not hurting anything to have an extra hole there. If it really bothers you, you could glass it yourself...
Vem2001
NYC
195S
That’s what it looks like someone messed up . I not concerned of the extra hole above the hose it’s the rectangular cut on the bottom . If it was free I wouldn’t care so much . If you look there’s like a bead of white silicone on both sides of the cut
It kinda odd as water can come through that opening defeating the need to silicone the sides . Do you have the same cut in your bay ?
Thermobrett
Lithia, Florida
SX195
I agree with the above mentions. You will notice weird “isms” the closer you looks. Watch for the shotty zip ties holding the cup holder drain lines in place. Guaranteed to fall off the first speed bump or pot hole your trailer hits.
Vem2001
NYC
195S
I notice stuff like that now . I found screws and metal shavings. That’s expected.
I’m just concerned about that cut out if it’s going to be a problem down the road .
LandSharksMom
195S
This makes me want to leave work and go look at ours to compare!!
Thermobrett
Lithia, Florida
SX195
I found several washers and screws that looked to be dropped in the bilge during assembly. Nothing seemed to be missing just “additional” hardware lol
evoixmr
195S
Mine has the same hole, but do not the rectangular cut-out
Vem2001
NYC
195S
Yes that ls “normal” leaving screws behind and shavings. It can create a problem .
Vem2001
NYC
195S
You do look at the cut below the hose on the floor that’s the cut
Vem2001
NYC
195S
Ok yes you’re right . I looked at the side of the hose .
Vem2001
NYC
195S
@LandSharksMom dont leave work if you do make it an emergency boating day . Lol but do check and post a pic when can. Thanks
