JASmith
- Minnesota
- FSH Sport
Hi, this is more of a brain storm thread than anything. I've done searching and found a few of you guys have done some pretty creative things to mount transducers on your FSH and I may end up following one of those in the end, but I always like to do the brain exercise "What would be the PERFECT solution".
Currently I have a Garmin 8610 head unit and the Force trolling motor that has the integrated transducer, it's the full monte with side scan, etc. So it's really good when the trolling motor is deployed, but useless when stowed. I'd like to have all that functionality put in the hull or on the transom, somehow, and still retain full side scan abilities. As you are probably keenly aware, there is so much stuff blocking side to side on the transom that I can't imagine a way to have a standard transom mount side scan be any more than about 50% effective. I'm slightly tempted to mount it to the bottom of the keel, as risky as that is.
I'm from Minnesota, so Freshwater, and depths typically less than 100 feet, until we get to Superior... maybe.
If you were to do it again, what would you do?
