Bimini top rear supports 2012 limited s
Gumbeaux
Words of advice....
I left the rear support legs attached to the Bimini top whole trailering. When the top is stowed for trailering, they are held in place only by the spring loaded "nub" that you use to adjust the height of the rear supports. Well, I lost one....
Rigged something up for the weekend...but I had to order the parts for long term and it cost me nearly $150....
Remove and stow those supports them before you trailer!
BoaterGuy
Words of advice....
I had one fall out while underway and I took it to my dealer and they just gave me a new one for free. Maybe try and contact your dealer??
BlacklimitedS
Edmond, OK
Moomba
Mine has a grey plastic c type clamp that holds it in place. I have a cover that zips over the entire top and attaches to the tower. I never thought it would come off while towing. Am I missing something? I want to be sure not to lose one.
davel501
Antioch, Illinois
The black knobs on mine come loose from time to time so I tighten them before every outing. Not sure how to get to $150 unless something else fell off.
Shuck Water
Frisco, TX
I lost one as well. My wife and I were cleaning the boat in our slip when I heard one of those words you never want to hear while on the water....."Oops" I kept my cool until I saw the replacement cost....$150 for a 8" piece of pipe....insane.
Gumbeaux
Maybe different on a 2014? I did not lose the piece with the plastic clamp...I lost the rear support extension below that attaches to the main top structure with one of those simple spring loaded buttons. I always simpley unpinned it at the the bottom and folded her up...
My cover goes around the whoel top, but does not extend enough to cover the ends of those poles....
Anyway...I was able to rig up a quick fix for the weekend with a 1/2 inch piece of conduit. Worked perfectly!
Gumbeaux
No black knobs on my 2012 bimini top...
must be different.
BoaterGuy
Gumbeaux
The black knob attaches your bimini to the tower...
oh, those. No. didn't lose those. Lost the rear support that have the pins that hold the rear support down to the brackets.
I am seriously thinking about banging out a few more of these with the conduit I had to purchase and offering to just send them to inmates here whenever they lose one. Takes about 5 minutes of cutting, pounding and drilling...
Gumbeaux
Just realized why maybe some people could be scratching their heads on this. I noticed a guy on the lake this weekend who stores his bimini differently than I do. I unclip the rear supports, wrap up the bimini, put on the cover and fold the whole thing forward and strap it to the wake tower. The boat I noticed this weekend had the rear supports in place, and the bimini was folded BACK and wrapped and covered. If you do it this way, then you won't lose those rear support extensions, but I am not sure it's as secure as my way for trailering.
Anyway, moving on...
