Carl Schwabe
- LS
I bought my LS2000 last fall and have only had it out three time when this happened. I was told that the now failed engine was replaced once before when I bought it. The cylinder seemed to have plenty of oil on it when I pulled it. Looks like the ring caught on the exhaust port on a down stoke. I did notice the engines did sound different from each other when I bought it, but being new to the whole jet boat thing I did not think anything of it.
So looking back at everything, it may have been showing signs of issues when I bought it.
1. The first time out last fall seemed uneventful except for being hard to start.
2. The second time out two weeks ago, I started in the yard before taking to the water. Seemed like I have to give it allot of throttle to get it to start, once started the both ran good. We stopped to swing ~1 hour and then started up. The port engine stalled several time at idle. After it warmed up it ran ok.
3. The third time out, again both engines seemed like they need allot of throttle to start. They both ran good ~1 hour and again we stopped to swim. When we started the engines up the port engine seemed to be lacking RPM at power with same throttle as the starboard. ~15 min of running the boat the port stalled at power but restarted, several times. We then took it in.
Compression at home was 115, 115 and 30. At that point pulled head and saw chunk out of head. There seemed to be a fair amount of oil on the piston when I pulled it so I do not think it is an oil issue.
I have not found any smoking gun.
I took the cylinder to a local machinist, He only had to take .25 mm off to clean the cylinder up.
I ordered three new oversized pistons.
Anything else I should look at?
I was told I should rebuild/clean the carburetor?
I did run water in the yard with hose to engines with out them running, while starting before I knew better, Could this have caused this issue?
Also where can I find the torque specs for the everything on the engine?
Thanks for any help
![20170610_190441r1.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/57/57693-99f4ae9ea7b97d9fb06a58e3f207cb1d.jpg)
Thanks for any help
![20170610_190420r1.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/57/57692-697eb07654d6bf3b50e930207189be80.jpg)
